Frequent Luffing Wire Rope Damage Issue
It is observed that the Wire Rope used for the Luffing Operations of our Crane is getting frequently damaged (2-3 Months - 100hrs of Working). There were no fouling observed at any point on the Crane and the Fleeting Angle is also within acceptable limits (0.7 Degrees as per the Supplier). We are using a 6x36 construction Right Hand Lay Wire Rope (Minimum Breaking Strenth 372KN) and is tightly wound on the drum.
Can any one provide any insights as to what might be causing this abrupt failure?
RE: Frequent Luffing Wire Rope Damage Issue
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
B.E.
You are judged not by what you know, but by what you can do.
Get a maintenance manual on this crane to be sure that all sheaves and drum have the proper diameters.
We had inspected the Sheaves and they were found to be alright(No signs of damage found on the sheaves as such).
(Image with marking of position of the cuts on the wire rope)
The spec's mentions RHO Wire Rope.
Can I know What factors would determine the Lay orientation of the Rope?
We were also discussing on the Fleeting Angle of the Wire Rope onto the Drumfrom the pulley amongst our team. The supplier mentions that the Fleet angle incorporated here 0.56 Degree which is according to him in the acceptable range(0.5 Degrees to 2.5 Degrees). Would increasing the Fleeting angle to say 0.8-0.9 Degree reduce the stresses during Overlapping of Wire Rope at Crossover points?
Many Thanks for your valuable inputs.
Have you discussed the problem with the crane manufacturer and the wire rope supplier? Is this crane used strictly for lifting and not for example dragging buckets? Any side loading taking place?
too-small radius. What does wire rope manufacturer say?
How did it last?
