JT assembly
JT assembly
JT assembly
Hi All,
I know it is possible to automatically save a JT file when saving aan .prt file containing a part. As far as my knowledge goes it is not possible to automatically save a .jt file from an assembly?
A JT file from a assembly is pretty useful since the guys in the shop can see how a machine is constructed :)
This JT file from the assembly can be aan single file version.
Does anybody know if I missed a setting which makes it possible to do the thing above ?
I don't mind if you guys can give me a viewer to view .prt files :)
Lars
NX10.0.3.5 native
adv.
RE: JT assembly
When you use file export JT, you can select from "File Contents" To export as a single file, or as an assembly and folder of the components...
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
