Butterfly control valves
We have two ductile iron water transmission mains transferring raw river water with low to medium sediment up to the treatment plant. The pipe diameter is 1600mm.
The two pipelines each need to incorporate a control valve to limit the flow to 3.646 m3/s
For this size of pipeline, has anyone any experience of using butterfly valves as a control valve?
I will check the cv or kv values and the % open etc. Just concerned about any abrasion erosion issues to consider.
John
John
RE: Butterfly control valves
http://www.dezurik.com/products/product-line/gate-...
