Boiler Water Return Flow Meter
We are looking for a flow meter that will be installed on the return line from our boiler to the steam drum.
The pressure is ~40 Bar & the water flow rate to the boiler is ~14,500 l/min.
Can someone recommend a technology/brand that can handle high temperature/pressure/multi-phase water flow?
Thanks in advance.
Thanks in advance.
RE: Boiler Water Return Flow Meter
