Outlet pipe from detention basin will have tailwater....what to do?
Hello everyone,
The detention basin has an outlet structure of a 3' x 3' box, with a V-notch weir on the entrance side and a 12" RCP stubbed into the opposite wall. I work with HEC-HMS. The pipe has a very flat slope (0.26%); it has tailwater. How would I figure the discharge going through the V-notch weir and over the top of the box - all before flowing into the pipe? Will HMS work? Or would you rather I use some other software or do hand calculations?
Thank you,
Bills Sis
Thank you,
Bills Sis
RE: Outlet pipe from detention basin will have tailwater....what to do?
Peter Smart
HydroCAD Software
www.hydrocad.net
for a spillway or weir, it might be easiest to input an elevation-discharge curve
if you have tail-water on your v-notch, suggest that this is not the best design. v-notch's should be designed without tail-water. Unlikely that you will be able to predict the discharge coefficient for a v-notch weir with submerged nappe.
Thanks again!
Found this one: http://www.fs.fed.us/biology/nsaec/fishxing/fplibr...
