Modeling walls
Modeling walls
I am modeling a steel fixture composed of W-sections. This fixture is a horizontal structure that will be used to hold a 40x20 building. I have modeled the fixture, but I need to model the building as well, in order to show the composite effect of the building. This building is just 4 walls and a roof. Here is my proposed procedure:
-Use the "Draw a Poly Area" to draw the walls and the roof.
-Assign>Area>Sections>Add new section>Thick shell>Modify Shell design parameters> Add material parameters
Is this the best way to model the walls and the roof, if I have a density, stiffness, and other material properties?
RE: Modeling walls
