Wood Truss
Wood Truss
Wood Truss
Got a wood truss spanning about 25', its about a 6:12 pitch. Is there a rule of thumb for the span/pitch and deflection? There is a wall at the center of the truss below, but I would not expect it to be load bearing, especially since over doorways, they didnt put headers in. Just wondering if they would have a wall to limit deflection?
RE: Wood Truss
For wood roof trusses, the deflection in inches due to live load cannot exceed the span in inches divided by 240 (L/240). For wood floor trusses, the deflection in inches due to live load cannot exceed the span in inches divided by 360 (L/360).
Creep can be up to 1/2 LL deflection
RE: Wood Truss
Usually, the deflection of moderate pitch roof trusses is not significant and is well above L/240
RE: Wood Truss
25' is no problem. Sloped trusses usually don't have big issues. You can run them 60' if you can get them on a truck.
(Very)General rule of thumb is X' span, X" deep. So 25' span needs 25" depth. You should have 6', so rock and roll.
When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.
-R. Buckminster Fuller
RE: Wood Truss
From my past experience as a wood truss designer, for typical loading scenarios, anything with a flat bottom and a pitch greater than about 4:12 tends to work just fine.
RE: Wood Truss
If they didn't install a slip joint at the top of the wall, it's likely that the wall is load bearing now to a certain degree, even if it wasn't intended that way.
RE: Wood Truss
If a panel point does not occur at that (intermediate) wall, the bottom chord of truss could experience undesirable stress.
RE: Wood Truss
Thanks, I was pretty sure it would be ok. I have never come across a truss that is loadbearing in the center. Also especially since the openings below in the wall do not have a header.
RE: Wood Truss
I've been in many a building where non-load bearing walls still have a header. Some carpenter's don't know any better and just frame every door opening the same.
RE: Wood Truss
My experience with one story wood framed buildings is the contractors build all of the interior walls tight to the underside of the trusses, without slip connections. It just seems to work. Maybe the trusses don't deflect much, maybe the interior walls become load bearing to a certain degree, maybe the bottom chord of the trusses flex upward, relieving the stress.
DaveAtkins
RE: Wood Truss
Quote (jrisebo)
In long-span situations, I've designed many buildings that have had intermediate (center) bearing points. Often, the truss manufacturer prefers it which, reportedly , would keep the cost down since they could avoid what would otherwise require a 2x8 or 2x10 bottom chord.
Quote (jayrod12)
I've seen this in smaller-span residential construction where the general contractor told me these are cookie-cutter houses that have previously been estimated and the material bill is constant.
Quote (DaveAtkins)
I've also seen this in smaller-span construction where i suppose deflection wasn't an issue. I also assume this was common practice in older construction where large spans were not in demand as today.
