Particle Collecting in Laser Etching
Need advice on specialist suction devices for "at Source" collection of small quantities of particles generated in a laser etching process.  The process will only generate a couple of grams of particles per hour.
I am particularly curious about off-the-shelf duct inlets ,nozzles and gas assist devices.   I have so far had to make them myself and would like some pointers on manufaturers who might make them.
any help would be much appreciated!
PCurry
Ireland.
RE: Particle Collecting in Laser Etching
You might want to search thru the Thomas Register or search the internet for "Dust Collectors". I make hair removal lasers and a lot of doctors buy a small vacuum device that picks up burnt hair that sounds like what you would want.
Good luck
Mark
Dont forget the area will only be as clean as the incoming air.  So a filter for that will be required.  Sound like you need a clossed chamber with filter inlet area. Try to use gravity to your advantage if possible.
You might want to look at www.exair.com. They make air amplifiers that I have used in similar applications.
