Wire with terminal lugs on ends as deformable/reusable part?
Hello all,
I am stuck in how to do this, is there any ideas how to do it properly?
It should follow the spline path, and it should orient lugs properly toward connecting element surfaces...
RE: Wire with terminal lugs on ends as deformable/reusable part?
Move Part - Along Curve ( NX Routing)
Lets you move a part using one of its ports as a reference, and specifying a line, a curve, a linear path, or a spline path to which you want to move the part.
After you specify the part to move, the port, and the curve, NX displays the Move Along Curve dialog box. You can specify a new location along the curve using the Move Along Curve dialog box.
regards,
Mathi Krishnan
NX10.0.1.4 D4
