Load on RHS beam
Load on RHS beam
Load on RHS beam
Hi not sure how much weight(kg) this beam can take. 150mm x 50mm x 2.0mm gal steel and the length of beam is 5.040m? Want to hang sliding doors from it if it can cope with the weight
RE: Load on RHS beam
Definitely sounds like it won't work. I recommend something with at least a 6mm wall. It needs to be 100mm wide at least just for mating geometry to door head.
