Constant Flow System Applications
Sorry for posting it one more time but seems the post was deleted as I cannot find it on forum and in my threads.
In a constant flow chilled water system with 3 – port valves, 2 PCHWP what is the standard way of controlling of the system during the low load conditions? Does switching OFF one of the pumps is acceptable ? IS there is a risk of starving some of the circuits in such a scenario?
Thank you for your help
RE: Constant Flow System Applications
No data for anyone to actually comment on.
My concern is if its feasible form the hydraulically point of view and if it wont cause starvation of some of the circuits.
Either that or turn one off, but flow through it and run the second one based on the combined flow temperature going out.
Very difficult to tell based on no data or schematic.
Or just set up a flow controlled bypass round your single chiller
This board is not a free Engineering service.
Hire an Engineer who will help you with this.
