Abaqus 2016 installation error
I had tried to install abaqus 2016 on my windows 10 but every time i got this error message and another one like that when installing 3DEXPERIENCE_AbaqusSolver, please help me:
compilation of OM dictionaries failed: rc= 9
Technical details:
Action LaunchAppAction from feature CODE\win_b64\Administration failed.
Action ID: ObjectModelerDicoCompiler_Done
Private ID: 67907a0d92ca2fa67e633796b8eb87e682ec93820f2f0241cd211f18974ff483
Error code: Type: ERROR, Error: 1, Owner: 30a
RE: Abaqus 2016 installation error
I searched the knowledge base: "The installation can fail with this error message if any files in the installation package extend over 260 characters including the file path." Basically install to a shorter root directory. Are you changing from the defaults?
I also created a blog on how to install Abaqus 2016 and another one on installing on Windows 10
I hope this helps.
Rob
Rob Stupplebeen
Rob's Engineering Blog
Rob's LinkedIn Profile
Thank you
I only changed installation directory from drive C: to drive D: and nothing more. (I had tried on drive C: too)
And I changed instalation directory to shorter path but the error messages are still remain an installation failed again. The errors are after copying files and while executing aplication on win_b64\code\bin\CATSTART... and the second error message is:
DSYAdmRegSrv failed: rc= 9.
Action ID: SetRegserver_Done
Private ID: 057655ca35d0cfb9baf719169f47b0fa971e9df10fa05f3a19e88a6fc912ddd4
I attach the installation log files for more information.
Unfortunately the Zip file wouldn't download. It could also be that the installation files are nested too deep. Try placing the install files in something like C:\temp then install into the default locations.
I hope this helps.
Rob
Rob Stupplebeen
Oh sorry, I can't download zip file and I don't know why?
I did what you said and put installation directory to E:\1 and installed on default location but did't work unfortunately.
I think the error messages could be related to 3DEXPERIENCE_AbaqusSolver\CODE\win_b64\Administration.zip file. could you upload it??
I uploaded Log files to another place: http://uploadboy.me/r77hlce2fbbl/SIMULIA_AbaqusSer...
Thanks for your aids.. :)
Hi
I have problem in Abaqus installation
In last step Setup i recive an error
Error: Unable to add Abaqus command directory to PATH variable.
Return Code: 1
Attempted to add command directory: "C:\SIMULIA\Commands Aba"
Technical details:
Action LaunchAppAction from feature CODE\win_b64\SIMCAE_TP.prd failed.
Action ID: addCommandsDirToPathVar
Private ID: 5b2c91af6bbc7606108d50396ed986d759fa64c7f1ad27a50be8932a084cc07c
what the hell am i doing?!!!
I assume that is the OS environment variable that links to the commands directory. With that the OS recognizes the "abaqus" or "abq2016" commands in a prompt.
In Windows you can create that PATH variable by yourself with a SET command or you go into the windows settings, display the environment variables and add the directory to the PATH variable manually.
