Pressure De-Rating Dampeners
Have a propane reinjection pump with suction stabilizer and discharge dampener.
Stabilizer: design temperature 100F @ 740 psig
Dampener: design temperature 100F @ 1480 psig
It turns out the fluid stream could be as high as 115F.
What codes are applicable to increase the design temperature by de-rating the design pressure. I can go down to 270 psig on the stabilizer and 970 psig on the dampener.
Any ideas?
Any ideas?
RE: Pressure De-Rating Dampeners
I'm trying to avoid talking with the manufacturer and getting a deviation from them.
With data you didn't supply us.
Sounds like it, yes. If it's a pressure vessel then unless it has two ratings then you need to get it re stamped.
