Non-constant E total, could it still be correct?
Hello, I have been reading around online and it seems that this should remain (at least fairly) constant throughout the simulation. I am modelling a bi-stable structure that has an analytical rigid part to move the object into its second stable state, by pushing it in a certain direction.
Because there is a considerable amount of internal energy stored when the structure is in its' second stable position, is it possible to have a step in my total energy? It is constant, then after the 'transition' there is a large drop and then it remains constant once again. I'm unsure if this is correct or not?
Any advice is appreciated.
