Tolerance stack up analysis for Dia 11.20H8 hole
I am a little bit confused about tolerances. Please can anyone help us. Please find the attached picture.
1) how much the Dia 11.20H8 moves vertical(-/+) at worse case when it fastened to Cap.
Loka
Loka
RE: Tolerance stack up analysis for Dia 11.20H8 hole
It's going to be impossible to inspect to this drawing as there is no orientation datum. One of the horizontal or vertical surfaces of the plate should be made a datum.
