Check out for offline working
Is there any method for checking out an NX dataset, for working offline, i.e. when not connected to server overnight, and once connecting back, to check in on the server?
Thank you
Thank you
RE: Check out for offline working
Assuming you know how to 'borrow' an NX license to your client for offline use, you'll need to learn and use the File -> Export Assembly outside Teamcenter... functionality.
After filling out all the required fields in all the appropriate Tabs, select the Checkouts tab: and check the box.
Next day, reverse the process by selecting File -> Import Assembly into Teamcenter. Fill out the Tabs and select the Checkouts tab and click on Check In.
A bit of cautionary advice...
Be sure you know how to use these menus and tabs.
Gary Bangs
www.flowserve.com
In the CATIA integration it saves the files in the CATUII folder.
But on NX it works "online" and if the connection to TC server is lost then the file won't save.
When you check-out CAD data the file is then copied to the specified location. You can then copy the part file to your mobile workstation or move it to a USB drive to take home. In the morning move the modified file back to the specified location and check it in. The part will then be moved back in to Teamcenter including any changes you made overnight.
Using this method your data is checked out so prevents anyone else modifying the data while you are working on it as opposed to just exporting & importing. Obviously test this method first as your Teamcenter impementation might behave differently.
Simon
A very nice option for single piece part files. I'll have to keep that one in my back pocket!
Have you tried it with an assembly?
g.
Gary Bangs
www.flowserve.com
It is ALMOST what I wanted.
The only problem is that now the "integrated" NX is working on a different version than this one.
The dataset is still checked out on TC, and the file is on the work folder defined on TC options.
But I can still open the file from TC with the "open in NX" button.
Is there any way to define it also in NX that it will point to the same file?
There's also a problem that if I checkout the NX dataset, and then I want to rename the named-references, it doesn't let me to check it in, saying it can't find the file.
I'm afraid that on a daily basis this switch could be quite harmful, and probably that's why the IT managers defined this feature off as default.
BUT this seems like we're on the way :)
Could you please try to help us little more with this?
Thank you
Garys solution to export/import via NX could be the best solution. As he says in his post, make sure you are confident what options you are choosing in the menus.
I will look again when I get some time.
