Determining contact pair surface on inside of a block
I have a vasculature branch that I want to embed into a block. I cut out the volume of the vasculature inside the block, but am having trouble with the contact pair. How can I define the inside surface of the block? I easily defined the surface of the branch but dont know how to define the same surface on the inside of the block. If I were to use the entire surface of the block would that work also?
RE: Determining contact pair surface on inside of a block
See CAE Users Guide 6.3 Using the selection options
