Why is engine and gearbox inclined?
Do some or all cars have the engine and gearbox at an incline of a few degrees? If so then why? Is it purely to get the engine and gearbox into better positions to fit in the car or is there more to it?
I've only worked on two cars in my life but both seem to have them inclined. I'm now building a custom chassis and wondering if I should do the same. There's zero fall (gradient/slope) in the sump of the Lexus V8 engine that I'm using, where the shallow area of the sump lets the oil flow to the deeper end of the sump, and I'm wondering if the incline of the engine is what's supposed to create the fall, so I need to mount my engine at an incline in the new chassis?
RE: Why is engine and gearbox inclined?
Mike Halloran
Pembroke Pines, FL, USA
Cheers
Greg Locock
I have a big SUV with IRS. I think the axle is a hypoid, partly so that the third row seats can fold into the floor.
In a custom car, you have the option of mounting the engine with the crank level, but you may end up with a tall tunnel in the floor pan, and the driveshaft may be above the input flange to any axle you can scrounge, unless you go for an antique part.
Mike Halloran
I did notice in my Suzuki Vitara (Sidekick/Tracker some parts of the world), the incline of the engine/gearbox lowered the rear driveshaft and hence lowered the driveshaft angle and wear on the driveshaft UJ bearings.
Cheers
Greg Locock
