Control Valve and On off Valve Designing data requirement
Dear all,
Can Any one suggest me any book on web or Link , where I can find all Basics for Designing Control valves, On- Off valves??
I want to make myself aware regarding all selection and basic parameters..I have gone through Emerson- Control valve Handbook
but still i want to know more. please suggest me any link or book on web.
Thank you in advance.
RE: Control Valve and On off Valve Designing data requirement
I'd go for Bela Liptak's "Instrument Engineer Handbook, Volume 2 - Process Ccontrol and Optimization". Liptak's series are considered classics.
Hard copies can be obtained for a little bit more than 200 USD http://www.amazon.com/Instrument-Engineers-Handboo...
Dejan IVANOVIC
Process Engineer, MSChE
I published a peer reviewed paper in SPE Oil & Gas Facilities that might be helpful.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
Please check following
1.Control Valve Primer - Hans Baumann -
2. Control Valve selection and sizing - Les Driskell
3. ISA handbook of control valves - Hutchison
I am sure with above 3 books you don't need anything else ..Ofcourse practical sizing experience can not be substituted by anything else...
This is not correct is it? You mean;
Designing with Control valves?
Keith Cress
Thanks to all for your guidance..
