Need help with a WPS / PQR
I just recieved a WPS / PQR for welding a 3'' SCH 160 and now my customer has changed their order to 4'' SCH 160. The question I have is do I rev up my last WPS / PQR or do i just disregard the 3'' WPS and just use the 4'' WPS
RE: Need help with a WPS / PQR
One must also consider the applicable construction code and whether the thickness involved required post weld heat treatment or whether notch toughness requirements must be met.
To sum up the situation in a few words; ASME Section IX is not the only code section that must be considered.
Best regards - Al
Not sure what you mean by "disregard the 3" WPS and just use the 4" WPS" ?
A bit more explanation may help,
DD
