Vertical vessel legs support
Dear,
Is there any standards for the design of the legs support in the CS vertical (small:L=2m&D=0.7m)pressure vessel containing 700 l of compressed air @ 40 bar, 20 C°.
In fact I can't find in the ASME BPVC Section VIII DIV 1 any indication. Else should I do the sizing using my manual calculation?
Regards.
Regards.
RE: Vertical vessel legs support
Mike
http://www.veerfabricators.com/p1.html
MJCronin
Sr. Process Engineer
Required thickness and dimensions must be determined by calculations using the design loads and allowable stresses at design temperature.
r6155
