Polyurethane vs FRP
Polyurethane vs FRP
Dear mates,
My contractor is offering me Polyurethane instead of FRP to coat a Crude Oil TK bottom, cost is half.
Any input will be apreciated.
RE: Polyurethane vs FRP
IF you need strength then FRP has big advantages.
Either way the adhesion is the primary issue, make sure that you know what combination of surface prep and base coats are being used to assure proper adhesion.
http://www.iso.org/iso/home/store/catalogue_tc/cat...
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
FRP is indeed a heavy duty coating. High build PU is very much abrasion resistant too.
So I would suggest if your Crude oil property is good for PU, then go for it!!
CocoE
http://gulfcoastpaint.com/wp-content/uploads/2015/...
Gulf Coast Paint PC-517 Cycloaliphatic Epoxy
