Read out NX partname and replace it
first to explain what I try to do:
First I read out the filename from a NX part (NX version 10) which looks in our company like this (1521w1_0.115, 1521w1_St_01, 1521w1_z_BG and so on).
Then I look with InStr for the "_" and add 1 to the result so I get a number for the Mid function. The result till now is our position number (1521w1_0.115==>0.115, 1521w1_St_01==>St_01, 1521w1_z_BG==>z_BG).
But now my problem, I need to replace all results which are like this St_01, St_02, St_03 with a special number. That means St_01 will be replaced with 01.100, St_02 will be replaced with 02.100 and so on.
At the end I will write an attribute called POS which contains either the result from POS or if the partname was St_01 the result of POS2.
Here what I have done till now:
Imports NXOpen
Imports System.Text.RegularExpressions
Module NXJournal
Sub Main()
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim Ergebnis As String
Dim zeichenposition As String
' das ist der filename ohne endung
Dim filename As String = workPart.Leaf
System.Windows.Forms.MessageBox.Show(filename)
' anzahl der zeichen
Ergebnis = InStr(1, filename, "_")
System.Windows.Forms.MessageBox.Show(Ergebnis)
zeichenposition = (Ergebnis + 1).ToString()
System.Windows.Forms.MessageBox.Show(zeichenposition)
' gibt aus "Positionsnummer"
Dim POS As String = Mid(filename, zeichenposition)
System.Windows.Forms.MessageBox.Show(POS)
' Stationen abändern
Dim POS2 As String
POS2 = POS.replace("St_01", "01.100")
POS2 = POS.replace("St_02", "02.100")
System.Windows.Forms.MessageBox.Show(POS2)
' Attribute
workPart.SetAttribute("POS", POS)
End Sub
End Module
Imports NXOpen
Module NXJournal
Sub Main()
Dim POS2 As String
' Attribute
End Sub
End Module
RE: Read out NX partname and replace it
So is what you're say that...
_St_nn
Becomes...
_nn.100
...and that nn can only be from 00 to 99
...and that there will never be any value AFTER _St_nn in the original string?
Skip,
Just traded in my OLD subtlety...
for a NUance!
Yes, so it is.
I changed my work to this, this will work now but I think its not really the best way to solve this.
Imports System
Imports NXOpen
Module NXJournal
Sub Main()
Dim POS As String
filename = workPart.Leaf
'System.Windows.Forms.MessageBox.Show(filename)
'System.Windows.Forms.MessageBox.Show(Ergebnis)
'System.Windows.Forms.MessageBox.Show(zeichenposition)
' gibt "Positionsnummer" aus
POS = Mid(filename, zeichenposition)
'System.Windows.Forms.MessageBox.Show(POS)
If POS = "St_01" Then Pos = "01.100" Else
If POS = "St_02" Then Pos = "02.100" Else
If POS = "St_03" Then Pos = "03.100" Else
If POS = "St_04" Then Pos = "04.100" Else
If POS = "St_05" Then Pos = "05.100" Else
If POS = "St_06" Then Pos = "06.100" Else
If POS = "St_07" Then Pos = "07.100" Else
If POS = "St_08" Then Pos = "08.100" Else
If POS = "St_09" Then Pos = "09.100" Else
If POS = "St_10" Then Pos = "10.100" Else
If POS = "St_11" Then Pos = "11.100" Else
If POS = "St_12" Then Pos = "12.100" Else
If POS = "St_13" Then Pos = "13.100" Else
If POS = "St_14" Then Pos = "14.100" Else
If POS = "St_15" Then Pos = "15.100" Else
If POS = "St_16" Then Pos = "16.100" Else
If POS = "St_17" Then Pos = "17.100" Else
If POS = "St_18" Then Pos = "18.100" Else
If POS = "St_19" Then Pos = "19.100" Else
If POS = "St_20" Then Pos = "20.100" Else
If POS = "St_21" Then Pos = "21.100" Else
If POS = "St_22" Then Pos = "22.100" Else
If POS = "St_23" Then Pos = "23.100" Else
If POS = "St_24" Then Pos = "24.100" Else
If POS = "St_25" Then Pos = "25.100" Else
If POS = "St_26" Then Pos = "26.100" Else
If POS = "St_27" Then Pos = "27.100" Else
If POS = "St_28" Then Pos = "28.100" Else
If POS = "St_29" Then Pos = "29.100" Else
If POS = "St_30" Then Pos = "30.100" Else
If POS = "St_31" Then Pos = "31.100" Else
If POS = "St_32" Then Pos = "32.100" Else
If POS = "St_33" Then Pos = "33.100" Else
If POS = "St_34" Then Pos = "34.100" Else
If POS = "St_35" Then Pos = "35.100" Else
If POS = "St_36" Then Pos = "36.100" Else
If POS = "St_37" Then Pos = "37.100" Else
If POS = "St_38" Then Pos = "38.100" Else
If POS = "St_39" Then Pos = "39.100" Else
If POS = "St_40" Then Pos = "40.100" Else
If POS = "St_41" Then Pos = "41.100" Else
If POS = "St_42" Then Pos = "42.100" Else
If POS = "St_43" Then Pos = "43.100" Else
If POS = "St_44" Then Pos = "44.100" Else
If POS = "St_45" Then Pos = "45.100" Else
If POS = "St_46" Then Pos = "46.100" Else
If POS = "St_47" Then Pos = "47.100" Else
If POS = "St_48" Then Pos = "48.100" Else
If POS = "St_49" Then Pos = "49.100" Else
If POS = "St_50" Then Pos = "50.100" Else
If POS = "St_51" Then Pos = "51.100" Else
If POS = "St_52" Then Pos = "52.100" Else
If POS = "St_53" Then Pos = "53.100" Else
If POS = "St_54" Then Pos = "54.100" Else
If POS = "St_55" Then Pos = "55.100" Else
If POS = "St_56" Then Pos = "56.100" Else
If POS = "St_57" Then Pos = "57.100" Else
If POS = "St_58" Then Pos = "58.100" Else
If POS = "St_59" Then Pos = "59.100" Else
If POS = "St_60" Then Pos = "60.100" Else
If POS = "St_61" Then Pos = "61.100" Else
If POS = "St_62" Then Pos = "62.100" Else
If POS = "St_63" Then Pos = "63.100" Else
If POS = "St_64" Then Pos = "64.100" Else
If POS = "St_65" Then Pos = "65.100" Else
If POS = "St_66" Then Pos = "66.100" Else
If POS = "St_67" Then Pos = "67.100" Else
If POS = "St_68" Then Pos = "68.100" Else
If POS = "St_69" Then Pos = "69.100" Else
If POS = "St_70" Then Pos = "70.100" Else
If POS = "St_71" Then Pos = "71.100" Else
If POS = "St_72" Then Pos = "72.100" Else
If POS = "St_73" Then Pos = "73.100" Else
If POS = "St_74" Then Pos = "74.100" Else
If POS = "St_75" Then Pos = "75.100" Else
If POS = "St_76" Then Pos = "76.100" Else
If POS = "St_77" Then Pos = "77.100" Else
If POS = "St_78" Then Pos = "78.100" Else
If POS = "St_79" Then Pos = "79.100" Else
If POS = "St_80" Then Pos = "80.100" Else
If POS = "St_81" Then Pos = "81.100" Else
If POS = "St_82" Then Pos = "82.100" Else
If POS = "St_83" Then Pos = "83.100" Else
If POS = "St_84" Then Pos = "84.100" Else
If POS = "St_85" Then Pos = "85.100" Else
If POS = "St_86" Then Pos = "86.100" Else
If POS = "St_87" Then Pos = "87.100" Else
If POS = "St_88" Then Pos = "88.100" Else
If POS = "St_89" Then Pos = "89.100" Else
If POS = "St_90" Then Pos = "90.100" Else
If POS = "St_91" Then Pos = "91.100" Else
If POS = "St_92" Then Pos = "92.100" Else
If POS = "St_93" Then Pos = "93.100" Else
If POS = "St_94" Then Pos = "94.100" Else
If POS = "St_95" Then Pos = "95.100" Else
If POS = "St_96" Then Pos = "96.100" Else
If POS = "St_97" Then Pos = "97.100" Else
If POS = "St_98" Then Pos = "98.100" Else
If POS = "St_99" Then Pos = "99.100" Else
' Attribut setzen
End Sub
End Module
Dim temp as String
For index As Integer = 1 to 99
If index < 10 Then
temp = "St_0" & CStr(index)
Else
temp = "St_" & CStr(index)
EndIf
If POS = temp Then
If index < 10 Then
POS = "0" & CStr(index) & ".100"
Else
POS = CStr(index) & ".100"
EndIf
EndIf
Next
CODE
Option Strict Off Imports System Imports System.Text.RegularExpressions Imports NXOpen Module Module1 Sub Main() Dim theSession As Session = Session.GetSession() If IsNothing(theSession.Parts.BaseWork) Then 'active part required Return End If Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Const undoMarkName As String = "regex replace" Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName) Dim myString As String = "1521w1_St_01" Dim outString As String = St_Replace(myString) lw.WriteLine("input string: " & myString) lw.WriteLine("output string: " & outString) lw.WriteLine("") myString = "1522z1_ST_34" outString = St_Replace(myString) lw.WriteLine("input string: " & myString) lw.WriteLine("output string: " & outString) lw.WriteLine("") myString = "1521w1_0.115" outString = St_Replace(myString) lw.WriteLine("input string: " & myString) lw.WriteLine("output string: " & outString) lw.WriteLine("") myString = workPart.Leaf outString = St_Replace(myString) lw.WriteLine("input string: " & myString) lw.WriteLine("output string: " & outString) lw.WriteLine("") lw.Close() End Sub Function St_Replace(ByVal inputString As String) As String 'change search string as needed Dim strRegex As String = "St_(?<num>\d\d)" Dim myRegex As New Regex(strRegex, RegexOptions.IgnoreCase Or RegexOptions.Multiline) 'change replacement string as necessary Dim strReplace As String = "${num}.100" Return myRegex.Replace(inputString, strReplace) End Function Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function End Modulewww.nxjournaling.com
