Abaqus Wheel and Rail interaction
Dear all
I have some problems when I model the wheel and rail.
I can do the wheel moving without rotation along the rail by giving the wheel velocity or displacement.
( The friction I apply is 0.3)
However when I try to make wheel rotate,
For example, I give the wheel U1 and free the UR3. It can only rotate a little bit and slide along the rail.
or
I give the wheel UR3 and free U1. The wheel can completely rotate but wheel will be larger and larger.
So how should I do if I want to make the wheel rotate without any problem.
RE: Abaqus Wheel and Rail interaction
"...but wheel will be larger and larger."
Try a different button for animating your results. The "growing" models are an animation thing I think.
Br,
Or the analysis was linear. Then large rotations lead also to "growing" parts.
