Pigging of GRE pipeline
Hi All,
Currently our project involves a 28" GRE pipeline. We would like to know if GRE pipeline can be used for intelligent pigging and also what shall be the minimum bend radius for GRE bends to allow passage of pig.
RE: Pigging of GRE pipeline
reach out to a pigging company, they are more than helpful for prospective business
Are you mad?
There isn't a single pig in the world that will pig a GRE line and provide any information worth having.
"Intelligent pigging" is designed for steel pipelines to detect corrosion internally or externally. GRE doesn't corrode. Why would you even want to do an "intelligent" pigging???
Bends in GRE tend to be more like elbows.
The key issue is the forces involved. Send an intelligent pig train down a GRE line and you can probably throw it away afterwards.
GRE is great stuff for piping and maybe above ground pipe / pipelines, but bury it and you're just asking for trouble. It is simply fundamentally not good pipeline material.
I've looked at design, installation and repair of the stuff and now wouldn't touch it with a bargepole for buried cross country lines.
I thought I had heard it all, but intelligent pigging a GRE line is up there with the best....
Apologies for being quite negative, but this is my experience and honest opinion.
Star to LittleInch for extreme restraint.
Mike Halloran
Pembroke Pines, FL, USA
