Advice on Plastic Casing/Enclosure
First time poster. I'm trying to find a casing for a project I am working on. Ideally if it works out well, then I will get thousands more made, so it's not just a 1 off.
I just need a plastic box of certain dimensions that is waterproof (in saltwater), has a lid and has a handle on one side, and needs to be relatively durable (nothing too heavy though).
I don't really know much about plastics at all, so am just seeking advice on what my different options are. So far I've investigated a few:
1. I've found a couple of electrical casings that are very similar size and will do, but I'd like a few variations. Is it easy to work with these? The size is fine, I just need to put on a handle and a clip (it needs to slide into something and then clip in), and then machine off the little ribs for the circuit board.
2. I could go to an acrylic worker and give them the dimensions.
3. I've asked an injection moulding place and they said a mould is usually around $20-$30k AUD which is not possible.
4. Looked into 3-D printing
I'm just hoping for pros cons on each, and any other suggestons I haven't thought of before I go down one path in too much detail. Open to any other options that people might have, as I have no idea on plastics smile
RE: Advice on Plastic Casing/Enclosure
Have you looked at Pelican cases?
Find a case that looks close to what you want, then speak to the manufacturer about modifying it for your purposes. That will be a lot cheaper than trying to design one on your own from scratch, unless you plan to make millions.
Dan - Owner
http://www.Hi-TecDesigns.com
