Phased Array Ultrasonic Testing (PAUT) - for qualifying GMAW-S
Am I interpreting the code correctly in ASME IX 2015 : QW-304 that with GMAW-S you cannot use RT but that tells me that UT is an option for qualification purposes. I am being told that UT in lieu of RT is not permitted.
RE: Phased Array Ultrasonic Testing (PAUT) - for qualifying GMAW-S
The code only limits RT, Since there is no limitation on UT and there are provisions to use it, there is no reason to say that it can't be used.
