What should I use to estimate extent of non-conformance escapes based off given sample
Greetings,
We've been purchasing castings for years now which were not 100% inspected.
We've since added some additional inspection to a few features and are now finding non-conformnaces in these areas.
There is no risk as they have always been there, so this is merely a paperwork exersize.
Anyway, due to the expense and low production rate of the castings, I only have a sample of about 20 parts.
I want to use this sample to "predict" the extent non-confomrnaces we likly have running in the field.
For the sake of this question, lets assume the data is normally distributed.
My initial though was to use a tolerance interval to show the likely "spread" of the non-conformances. I used a 95% confidence level over 99% population interval.
What are your thoughts on this? What would you use?
I am running minitab to do this.
VS
VS
RE: What should I use to estimate extent of non-conformance escapes based off given sample
> why not remove the requirement if the non-conformity is inconsequential?
> how do you know that what you do see is as bad as it gets? i.e., where there's smoke is often a fire.
Have you looked at MIL-HDBK-109?
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
I'm just a small fry.
There was a company wide procedure implemented revolving around product verification. The design engineers then ran the part through the works and came out with a number of features that need to be monitored.
The risk is extremely low as the process is stable and the part/design and production method are tried and true (40 years) with no failures.The concern is that if a freak process drift were to occur and this feature were to escape durastically non-confomring (which was deemed possible by the risk assessment performed by the design engineers... eh.) it could result in a catastrophic failure. The procedures previously used to buy-off this absolutley minimal risk are no longer in place, so now we must monitor this feature as per the new proceedures. I can't change the hand I was dealt.
We've simply shined a spotlight on a skeleton we all knew was there -- and now must do our due diligence by aligning an auditable papertrail.
This is very common with castings, the more you inspect, the more you'll find wrong.
Anywho...
I know that what we see in this 20 part sample is NOT as bad as it gets. That is why I'm thinking of using a tolerance interval in minitab to help predict what the "bad as it gets" will likly be.
Any thoughts on the statistics side? Does a tolerance interval sound like the right tool?
VS
The mil handbook has the statistical background for creating sampling plans and evaluating potential failure percentages. My forte isn't in this arena, but I suspect that your approach will only work for large numbers of samples in a larger pool of product. The sampling plans that the military came up with should work with smaller lots. The link to MIL-HDBK-109 is here: http://quicksearch.dla.mil/qsDocDetails.aspx?ident... Unfortunately, the scan quality is pretty bad, but it's mostly readable.
TTFN
