Calculation of the inducted currents
I am looking for an approved method to calculate induced current on a metallic armour.
Fiber optic cable is buried in the same trench as power cable (230kV cable) - the distance is about 1ft. The fiber optic cable has armouring (steel wires). I am looking for a IEEE standard or method to calculate induced circulating currents on a fiber optic shield (shield is grounded both ends). Also; to perform calcs to determine standing voltage of one end (if one end is grounded).
thanks.
thanks.
RE: Calculation of the inducted currents
http://www.epri.com/search/Pages/results.aspx?k=EL...
See also:
ANSI/IEEE Std 575-1988 IEEE Guide for the Application of Sheath-Bonding Methods for Single-Conductor Cables and the Calculation of Induced Voltages and Currents in Cable Sheaths.
