I-Deas 12 model file size
Is there a known size limit for model files in I-Deas 12. One of our guys has twice had problems when his model file has reached the 2.6 to 2.7 Gig range. We suspect that is the problem.
RE: I-Deas 12 model file size
I don't remember the exact limit, but it was just over 2Gb, IIRC, so you are probably correct.
I-deas is a 32-bit app and as such, cannot address more than ~2Gb in memory. When your MF files are near that, it's likely trying to load at least that much and thus you hit a problem.
Not sure if older posting on GTAC might have tips to handle it, but they they basically boil down, as you might guess, to dealing with smaller chucks of data at a time.
Good luck.
Pat McManus
Siemens PLM
