What is this?
What is this?
Hello, how to call this in English?
RE: What is this?
Nautical Rope Fittings, Decking Rope - Google Image search
Gary Bangs
www.flowserve.com
RE: What is this?
RE: What is this?
RSVP
RE: What is this?
Ted
RE: What is this?
RE: What is this?
Ted
RE: What is this?
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
RE: What is this?
RE: What is this?
RE: What is this?
B.E.
You are judged not by what you know, but by what you can do.
RE: What is this?
-handleman, CSWP (The new, easy test)
RE: What is this?
Mike McCann, PE, SE (WA)
RE: What is this?
RE: What is this?
Drapery/ curtain hardware like a "hanger" is generally not nearly so sturdy.
Handrail "stanchions" may be short or quite a bit longer.
The name depends on the application, but none of the words in common use maps to a particular style, geometry, material, or load rating with any certainty, so you can't reliably order what you want without a picture and a model number.
Mike Halloran
Pembroke Pines, FL, USA
RE: What is this?
RE: What is this?
For curtains it would be Zn with a flash coating and it could hold 10-20kg.
The boat rail bracket is Cr plated brass and ti will probably support more like 100-150kg.
