Changing body Line widths Journaling VB
Hi All,
I found this piece of code on here which I tweaked to my needs..
Originally it changed the body color to red but I tweaked it to change the line width to 0,5 mm
Problem is that the type filter is wrong. I would like it to be set to solid body but that part isn't working.
CODE --> vb
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
'   Menu: Edit->Object Display...
'   Dialog Begin Edit Object Display
'   Dialog Begin linewidth
Dim markId4 As Session.UndoMarkId
markId4 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Edit Object Display")
Dim displayModification1 As DisplayModification
displayModification1 = theSession.DisplayManager.NewDisplayModification()
displayModification1.ApplyToAllFaces = False
displayModification1.ApplyToOwningParts = False
displayModification1.NewWidth = DisplayableObject.ObjectWidth.Five
Dim objects1(0) As DisplayableObject
'Dim body1 As Body = CType(workPart.Bodies.FindObject("BLOCK(1)"), Body)
Dim body as DisplayableObject
Dim Resp as integer
Resp=SelectAnObject ("identify body",body)
objects1(0) = body
displayModification1.Apply(objects1)
displayModification1.Dispose()
'   Menu: Tools->Journal->Stop Recording
End Sub
Function SelectAnObject(prompt As String, _
               ByRef selObj As DisplayableObject) As Selection.Response
       Dim theUI As UI = UI.GetUI
       Dim cursor As Point3d
       REM Dim typeArray() As Selection.SelectionType = _
          REM {   Selection.SelectionType.All, _
              REM Selection.SelectionType.Faces, _
              REM Selection.SelectionType.Edges, _
              REM Selection.SelectionType.Features}
	Dim selectionMask_array(1) As Selection.MaskTriple
        With selectionMask_array(0)
            .Type = UFConstants.UF_solid_type
            .Subtype = 0
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
        End With
        response = ui.SelectionManager.SelectObjects(message, title, scope, _
                                         selectionAction, includeFeatures, _
                                     keepHighlighted, selectionMask_array, _
                                                      selectedObjects)
       Dim resp As Selection.Response = theUI.SelectionManager.SelectObject( _
               prompt, "Selection", _
               Selection.SelectionScope.AnyInAssembly, _
               False, typeArray, selobj, cursor)
       If resp = Selection.Response.ObjectSelected Or _
               resp = Selection.Response.ObjectSelectedByName Then
           Return Selection.Response.Ok
       Else
           Return Selection.Response.Cancel
       End If
    End Function
End Module
What I changed is below.
CODE --> vb
            .Subtype = 0
        End With
                                                      selectedObjects)
       Else
       End If
    End Function
this gives me the following error...
UFConstants is not declared, and after that a bunch of other errors but I would like to tackle this one first...
What did I do wrong here?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
RE: Changing body Line widths Journaling VB
Quote (nutace)
UFConstants lives in the NXOpen.UF namespace. To fix this particular error, you can do either of the following:
  1. import the NXOpen.UF namespace. At the beginning of your journal file add the line:
    CODE
    Option Strict Off
    Imports System
    Imports NXOpen
    Imports NXOpen.UF
  2. OR
  3. Use the fully qualified name for UFConstants.
    CODE
                .Type = NXOpen.UF.UFConstants.UF_solid_type
                .Subtype = 0
                .SolidBodySubtype = NXOpen.UF.UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
            End With
    Technically, the NXOpen part highlighted above wouldn't be necessary because you have already imported the NXOpen namespace. Importing a namespace acts like a shortcut, eliminating some otherwise redundant typing.
www.nxjournaling.com
I think this is what you are looking for (I copied portions of a journal posted by cowski)
CODE --> VB
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Dim body() as TaggedObject
If SelectAnObject("identify body",body) = Selection.Response.Cancel Then
  Return
End If
Dim objects1 As New List(Of DisplayableObject)
For Each temp As TaggedObject In body
    objects1.Add(CType(temp, DisplayableObject))
Next
displayModification1.Apply(objects1.ToArray)
End Sub
               ByRef selObj() As TaggedObject) As Selection.Response
       Dim title As String = "Select one or more bodies"
       Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
       Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
       Dim includeFeatures As Boolean = False
       Dim keepHighlighted As Boolean = False
       Dim selectionMask_array(0) As Selection.MaskTriple
           .Subtype = 0
           .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY
       End With
       Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects( _
         prompt, title, scope, selAction, _
         includeFeatures, keepHighlighted, selectionMask_array, _
         selobj)
       If resp = Selection.Response.Ok Then
       Else
       End If
End Function
End Module
Thanks Both!
Got it working!
NX9 / TC10.1.2
HP Zbook15
