Heat treatment at 1300 DegC
Dear Expert,
My client ask me one question, "What would be the result of using temperature 1300 Deg C in heat treament for Carbon Steel". Pls advice me to answer this question.
RE: Heat treatment at 1300 DegC
"Even,if you are a minority of one, truth is the truth."
Mahatma Gandhi.
as Arun said, @ 1300°C you're not doing heat treatment, you're almost melting it. depending on the geometry, the part won't even hold its own weight.
Most alloys have significantly lower melting points than pure metals. Some incipient melting would not be unexpected at 1300C.
In some processes this is done on purpose. When they make Si steel (for transformer laminations) they reheat the slabs before hot rolling to about 1250C, and they 'sweat' a low melting point Fe-Si compound. It is a way of homogenizing the ingot and removing pockets of high Si.
"actually pure iron holds strength better than most alloys. We used to build retorts for sintering furnaces out of 1002, and they ran at 2350F (1288C)"
Ed, you are right ,for salt bath electrodes, low carbon steel (< 0.1%), would perform better than 35/15 (Grade HT).
Mahatma Gandhi.
