Telescopic Strut.
Telescopic Strut.
I am looking for a telescopic strut for a marine application (think camera tripod or monopod). I need it to collapse to 800mm or less and extend to 1800mm. Max load is 100 kg axial. Problem with available tripods they all seem to have friction locking only. I need positive locking (pins perhaps?) but without backlash (so it needs friction or clamping as well).
The strut will act as one leg of a tripod for towing a sub-surface apparatus. Depth of the apparatus will vary from 600 mm to completely out of the water.
Alternatively a linear actuator (either 12v or manual) that meets the above specs might do the job.
je suis charlie
RE: Telescopic Strut.
http://www.unistrutohio.com/telescoping-square-tub...
Cheers
Greg Locock
http://www.ebay.com/itm/Vintage-Tripod-Screw-Bumpe...
Then you could adjust it and and it would stay in place. You could motorize it if you wanted to.
If you absolutely require a reliable friction clamp, you don't need the positive lock, except perhaps as a fail safe device.
Could you use a hydraulic or pneumatic ram extended to solid height?
JHG
Cheers
Greg Locock
B.E.
You are judged not by what you know, but by what you can do.
Greg, I forgot to mention. Length needs to be adjustable in increments of 100mm (4") or less.
je suis charlie
