Vibration assessment of lab floor to vc-b - query on use of one-third octaves
I am carrying out a vibration assessment of a concrete floor in a laboratory building. Certain areas of the facility are to achieve the vc-b criteria which is defined in terms of a limiting rms velocity for any given one-third octave band between 0-80Hz. The building is currently under design and so I am using FE to analyse the floor for vibrations due to footfall. My interpretation of the use of one-third octaves is that for each mode between 0-80Hz I should calculate the velocity response. For each one-third octave band I should then calculate the rms velocity by considering the velocity response of all modes that ie within that band. I can then plot a spectra of rms velocity against central frequency over the 0-80Hz range to compare against the allowable velocity.
I am a structural engineer and we do not typically use one-third octave bands so if my interpretation is incorrect then please excuse my ignorance. Any advice on whether the above approach is correct or not would be welcomed.
RE: Vibration assessment of lab floor to vc-b - query on use of one-third octaves
Anyway once you've done that the energy in the third octave is the sum of the energy in the lines in the narrowband spectrum.
Cheers
Greg Locock
