Problems with batch exporting in NX 9.0
Hi All,
I have been trying to automate moving and translating files. I basically have all the code done and I'm using the "ug_inspect.exe -extract_all". I'm trying to export a whole assembly into one parasolid, and it seems like the only thing that is exporting is a body feature that is in the assembly itself.
I was wondering if anyone knows if there is a way to change this? Perhaps somewhere in NX's options? OR maybe in my code?
CODE --> batch
@ECHO on
ECHO "%~1"
SET "trufolder=%~1"
SET "moddate=%DATE:~4,2%%DATE:~7,2%%DATE:~12,2%"
SET "filename=%~n1"
SET "shortname=%filename:~0,8%"
SET "datefolder=D:\Quotations\Customer Files Recd\%shortname%\files recd %moddate%"
MD "%datefolder%"
CD /D C:\Program Files\Siemens\NX 9.0\UGII
ug_inspect -extract_all "%trufolder%" "%trufolder%"
move /-y "%trufolder%*.x_b" "%datefolder%\%filename%.x_b"
start "%datefolder%\%filename%.x_b"
RE: Problems with batch exporting in NX 9.0
The "ug_inspect -extract" option will only extract bodies contained within the file. Unfortunately for you, the assembly file does not contain the bodies of the components. It contains links to the component part files. When you open the assembly, the components are loaded and positioned accordingly.
I don't think "ug_inspect" is up to the task. However, a journal could be made to open the assembly file, load the components, and export the assembly to a single parasolid file. With a few tweaks, such a journal could be made to work in 'batch' mode, where it is called with the command line utility 'run_journal'.
www.nxjournaling.com
Thank you cowski. I will look into that.
I have my journal set up and it works great when I have NX open, but I can't seem to pass the data on to the .vb from the .bat. From what I have seen others saying, you can enter "c:\path\run_journal.exe C:\path\journal.vb -args c:\path\part.prt". When I do this I get an error that says "Runtime error: System.nullReferenceException: Object reference not set to an instance of an object. Do I need to add some code to the .vb file to tell it to look for the info from the .bat file?
In your journal file, you will need to examine the arguments that have been passed in. Check that "args" contains a valid file path, then open the file so the journal can operate on it.
I ended up finding a journal on a forum that worked for me. Thank you for your help.
CODE --> vb
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Imports NXOpen.Utilities
Imports NXOpen.Annotations
Module ChangeNoteWord
   Dim s As Session = Session.GetSession()
   dim lw as listingwindow = s.listingwindow
	Dim dp as part
	Dim wp as part
 Sub Main(args() as string)
	lw.open
	OpenPart(args(0))
   Dim nc As NoteCollection = dp.Notes
   Dim notetext1 As String = "existing word"
   notetext1 = "COOL"
   Dim notetext2 As String = "new word"
   notetext2 = "TEST"
   Dim notestring() As String
   Dim nolines As Integer = 0
   Dim found1 As Boolean = False
   Dim m1 As Session.UndoMarkId = s.SetUndoMark(Session.MarkVisibility.Visible, "M1")
   For Each a_note As Note In nc
     notestring = a_note.GetText()
     nolines = notestring.Length
     For i As Integer = 0 To nolines - 1
       found1 = notestring(i).Contains(notetext1)
         If found1 = True Then
          notestring(i) = notestring(i).Replace(notetext1, notetext2)
         End If
      Next
      a_note.SetText(notestring)
   Next
   s.UpdateManager.DoUpdate(m1)
   Dim partSaveStatus1 As PartSaveStatus
	partSaveStatus1 = dp.SaveAs(("R:\Engineering\Program_Files\temp_file\temp.step"))
	partSaveStatus1.Dispose()
 End Sub
 sub OpenPart(byval thePart as string)
	Dim basePart1 As BasePart
	Dim partLoadStatus1 As PartLoadStatus
	basePart1 = s.Parts.OpenBaseDisplay(thePart, partLoadStatus1)
	dp = s.Parts.Display
	wp = s.parts.work
	partLoadStatus1.Dispose()
End Sub
 Public Function GetUnloadOption(ByVal dummy As String) As Integer
  GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
 End Function
End Module
