Digital Buck Data
Digital Buck Data
Happy Monday!
Could somebody explain me what Digital Buck Data means and what is used for?
Any general information about this topic will be greatly appreciated........
Thanks!
Thanks!
CAD 2015
RE: Digital Buck Data
Read the response from TDIMeister on
thread71-223909: 3D Softwear for Engine Fit-Up
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
CAD 2015
Digital buck means the jt visualisation data that is used only for viewing,clash checking,clearance analysis.It is used in the Application called Teamcenter vismock up a product of SIEMENS.The CAD data from the teamcenter is converted to the jt format which is called as "digibuck" and the same is opened in vis mock up application for the purposes mentioned here.Hope it helps.
