Peel test for Brazed joint as per ASME IX 2015
Hi
our client has requested us to perform peel test on a brazed lap joint. i have never done it before so i have performed 1 test in which i have bend 1 section of the plate. During bending the plate broke at the brazed joint. Now the requirement of ASME IX is to check for discontinuity on the faying surfaces. I have attached 1 photograph in which i have marked the faying surface. Can you guys please guide in the interpretation of the surfaces.
Thanks in advance.
Thanks in advance.
RE: Peel test for Brazed joint as per ASME IX 2015
