Solidwork Routing
Solidwork Routing
Hi Guys
I've recently moved back to SW from inventor and trying to get a handle on routing and specifically introducing my own compression fittings (swagelok)
I've immediately ran into problems defining bulkhead connectors and adapter elbows :
Adapter elbow : There is no option to introduce elbows in the library wizard , or to have two different connection
Bulkhead connector : problem relates to the component snapping to geometry , as it has no hydraulic connection to the "thru hole" how do you define its mating feature ie its looking for a tapped hydraulic hole
Any help or work around would be appreciated
Geoff
Geoff
