Dear Friend I have to fabricate
Dear Friend
I have to fabricate a tubesheet (3000 mm dia x 70 mm thk) from SA240GR.316 Plate material.
Any one can help me to understand
1)the permissible minimum plate width ( as per code)?
2) as well code permissible welded Tube-sheet from plate?
3) NDT & Testing requirement as per code?
Thank you
Omio
Thank you
Omio
RE: Dear Friend I have to fabricate
We here can't tell you which code to follow.
Your customer or the third party having jurisdiction should do that.
Mike Halloran
Pembroke Pines, FL, USA
Typically TS this size are from custom rolled plate.
Please share your past experience if anybody came across such Tubesheet manufacturing ?
thanks in advance
This is an heat-transfer /thermodynamics forum.
