Making Drafting Setting permanent.
Whenever I start the application and open a Model file, I have to change the Drafting Settings. The settings are like Decimal Places, Decimal Delimiter etc. I tried to set it in Customer Default but it did not worked. What is the correct way to set it permanently?
RE: Making Drafting Setting permanent.
But you should check, in there, the site settings(If any). It might be the company settings which are overruling yours.
Also check if you have the setting " Save user settings on exit " (out of my head) switched on...and if the path where your user settings supposed to be saved is accessible for you.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
and save every user setting before exiting the customer default....
what to do next...
Have a look at https://vimeopro.com/phoenxplm/tips-and-tricks/vid... and it might help to point you in the right direction.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (29versions)
