Concentric vs. Eccentric Manhole Cones
What is the purpose of a eccentric manhole cone versus a concentric manhole cone? When do you use either. Do you use a eccentric cone because steps need to be bolted into a vertical surface for climbing in and out?
RE: Concentric vs. Eccentric Manhole Cones
yes. Also, you can rotate to miss curb lines etc...
Try climbing a ladder that's tilted toward you.
Mike Halloran
Pembroke Pines, FL, USA
Don't put in steps. They rot over time and turn into safety hazards.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
All the steps I see in manholes are HDPE or similar.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
some agencies around here do not allow steps on sewer manholes. makes it too easy to avoid following the SWP which requires a fall harness and tripod
Correct. The flat surface allows for placement of a ladder or manhole steps. The ladder is recommended to be frp or stainless steel construction for corrosion resistance.
Chris Eberly, PE
www.parkusa.com
