Zick analysis, stress at horn of saddle
Dear all,
"Pressure vessel design manual" by Dennis Moss, Procedure 3-10, stress at horn of saddle S9 saying ts^2 =ts^2+tw^2. "Pressure vessel handbook" by Megyesy, 14 edition page 89, stress S4 saying ts^2 "may be" thickness squared adding together. (same as Moss, but "may be").
PV Elite is using ts^2 =(ts+tw)^2, which will give less compressive stress. Compress is using the formula from the book that will give higher compressive stress. PV Elite says no over stress while Compress says overstressed in one of our drum. I wonder who is right.
Liner combination of thicknesses by PV Elite seems correct as it is the basic concept of mechanics of material, just like stacking two beams together with both ends simple supports and having loads from top side.
Any thought which equation is correct ?
RE: Zick analysis, stress at horn of saddle
To me, this would imply the PVE expression ts^2 =(ts+tw)^2. The Moss expression would seem to neglect the term "+2tstw", which could be negligibly small, or not.
No idea which, if any, is correct. I suspect a person would have to go the original paper.
In my class of work I am skeptical of Zick. If the calculation says overstressed, I don't exactly believe it. If it says not, well, I don't exactly believe that either :)
Mike
2ts*tw is not negligibly small. For both vessel and wear plate = 1", 1^2+1^2 = 2 per design books and Compress, while (1+1)^2= 4 per PV Elite, and then crunching into the Zick stress formula, the former will yield 100% more compressive stress than the latter, that causes Compress to say overstressed while PV Elite saying ok.
Our vendor is using PV Elite and unwilling to add additional stiff ring, threatening for cost impact if added, while our in house using Compress asking for additional stiff ring.
In addition to that, Compress went further to check stress at the edge of wear plate and also indicating overstress that I think it is overkilled, since no paper asking to check stress at the edge of wear plate, and edge of wear plate is not the actual horn of saddle which is a pinch point that has significant compressive stress. The same stress formula shall not be applied to edge of wear plate where it is flexible, not a pinch point. In my opinion stress diminishes quite sharply from the actual horn of saddle to the edge of wear plate.
I only have the one reference, Bednar, but looking at the example problem, it does use (ts+tw)^2.
I would generally agree with the statements in your third para.
Mike
1)PD 5500 - 2015
2)Original Zick (attached)
r6155
Mike
In PD 5500:2015 is (tshell + twear plate)^2
In original Zick is (tshell^2 + twear plate^2)
r6155
Compress is using the old Zick paper and way too conservative.
