Access VBA Linear Interpolation
I am trying to use Access VBA code to interpolate (linearly) and return values to a table. I am still very new to both Access and VBA coding, so please be kind and clear any responses--I appreciate it!
Going off of this formula: y2 = [(x2-x1)(y3-y1)/(x3-x1)] +y1
My x2 column is in a table called "Calculation Sheet", while my x1, x3, y1, and y3 values are in a table called "Lookup Table" (x1,x3 in the same column in increments of 50, y1 and y3 in another column). I am trying to get the Access VBA program to find the y2 value from interpolation "Lookup Table" and return the value back to "Calculation Sheet" in another column for y2, which corresponds to x2 values.
I am at a loss for how to execute something like this and what the best way would be (sub vs function, SQL vs VBA code, etc). Any assistance appreciated, thank you!
RE: Access VBA Linear Interpolation
hi,
So how does x2 relate to your lookup table? I'd GUESS that x2 are values between x1 and x3
I'm an Excel guy much more than an Access guy. I'd be apt to query the table from Excel and do the interpolation in an Excel sheet
So you'd have a column like...
X-Values Y-Values
1
10
20
30
40
50
...where 1 and 50 are values from Lookup Table and 10-40 are values from Calculation Sheet.
Unfortunately, you have supplied no other data: No Lookup Table values nor Calculation Sheet values.
Skip,
glassesJust traded in my OLD subtlety...
for a NUance!tongue
Hi Skip,
Yes, my x2 values are between x1 and x3.
Let me provide some sample data, sorry about that:
x values (lookup)-----y values (lookup)
1820100------20000
1820150------ 19250
1820200------ 18500
1820250------ 18250
1820300------ 18000
and say my sample x2 value is 1820122.
Did you mean that your intermediate x value is 1820122 not 180122
Skip,
for a NUance!tongue
1) I created a Structured Table using your data, named LkupTbl...
X-Values	Y-Values
1820100 	20000
1820150 	19250
1820200 	18500
1820250 	18250
1820300 	18000
2) I broke the formula down into factors...
x2_      	1820122
match Row	1	=MATCH(x2_,LkupTbl[X-Values],1)
x2_x1   	22	=x2_-INDEX(LkupTbl[X-Values],match_Row)
y3_y1   	-750	=INDEX(LkupTbl[Y-Values],match_Row+1)-INDEX(LkupTbl[Y-Values],match_Row)
x3_x1   	50	=INDEX(LkupTbl[X-Values],match_Row+1)-INDEX(LkupTbl[X-Values],match_Row)
y1_      	20000	=INDEX(LkupTbl[Y-Values],match_Row)
y2_      	19670	=x2_x1*y3_y1/x3_x1+y1_
Skip,
for a NUance!tongue
Yes I meant 1820122. Thanks for pointing that out, and thanks for giving me something to translate into Access! I'll have to work the syntax a bit but otherwise it makes sense!
I've finished school so this is not an assignment. I'm trying to learn VBA coding in an Access environment.
Sorry. You might have a better chance of achieving your objectives at our sister site, http://www.tek-tips.com/threadminder.cfm?pid=705 in the Access VBA Forum.
Skip,
for a NUance!tongue
