suggestions for socket protection
Hi. I am using a motorized AC power cable reel for my electric charging station. The AC cable reel uses a industrial socket which is connected to the plug in the vehicle. I am facing an issue here. The socket gets damaged with frequent usage as it brushes against the road. To solve this I was thinking of a something like circular ring roller around this socket with ball bearings so that the socket doesnt brush the road and only the roller would get damaged which can be replaced. Can anyone suggest something like this available in the market or online or please let me know if there are better ideas .
Attached a picture of the socket being used.
RE: suggestions for socket protection
My first thought was retaining it with a hose clamp or two, but they're very easy to overtighten, so there's some danger of cracking the socket or cutting the cable insulation. Maybe some RTV sealant on the inside of the hose, which can be peeled off with relative ease, especially if you use the cheap filled stuff that's sold for house caulking. Plus seize the ends with some fat twine.
Mike Halloran
Pembroke Pines, FL, USA
I've already put a reply in in the Electrical/Electronic engineering other topics Forum.
A.
I’d unplug the darn thing before you drive the car. That way the plug won’t be dragging on the road.
