Calibration of Vessel Load Cells.
How do you calibrate or check the calibration of vessel weighing system. I believe you can hang test weights off them but how are these generally mounted and are the weights sufficient to make a serious change in output.
Any other info about loads cells would be greatly appreciated.
RE: Calibration of Vessel Load Cells.
