How to use Knowledge Fusion?
I would like to  create a model in UG by UG/OPNE API to  invoke a class which is built in Knowledge Fusion. Who have did this? I would like one cue.
RE: How to use Knowledge Fusion?
There is a detailed tutorial in the KF section. I suggest you go thru that and you should able to generate/write your own special wizards.
