Unable to open the same ansys workbench file on a different computer
Dear All,
I have prepared a project on ansys workbench 15 in one computer, now i wanted to further work on that file but on a different computer. I emailed the wpbj file and tried to open the file another computer but i am unable to open the file this error pops up every time :
"the project file directory does not exist. A valid project must have its corresponding project file directory. If the project file has been renamed you should also rename the project_file at the same location."
Can anyone tell me what is the proper way to transfer wokbench file to a different computer. Note that both systems have Ansys workbench 15.
Inam
Inam
RE: Unable to open the same ansys workbench file on a different computer
Rick Fischer
Principal Engineer
Argonne National Laboratory
Use the archive project option - this might help you get a small file and it is easier to transfer between computers.
I think using a USB will tkae you less time...
