External pressure
External pressure
External pressure
Dear,
Can someone tell me how to calculate the computed longitudinal compressive stress which will be compared witch the value of the B factor outlined in the ASME BPV code UG-23(b) and why (b) is only concerned by The maximum allowable longitudinal compressive stress and non by The maximum allowable circumferential compressive stress ?
Reagrds.
RE: External pressure
The computed long.compr.stress is what you calculate as the stress in the vessel wall corresponding to the loading state you are examining. A common use of this procedure is with a tall vessel (tower) subject to wind or earthquake loading together with internal pressure or vacuum.
For the circumferential compressive stress you go to UG-28.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
Hi Prex,
So do you an idea how to evaluate this longitudinal compressive stress, maybe you van give me an example if you want ?
Thanks.
Usually calculated as F/A.
F may be zero, A may not.
Mike
