Volume calculation (Bidirectional)
Hello all,
I have designing a Rectangular Tank and have measured the actual volume by using the Split with surface and Measure option in CATIA.
I would now like to calculate the surface position from the bottom of the Tank for a Specified Volume (Opposite case). Any ideas on how to approach this problem.
One method I have found is by using the CATIA Product Engineering Optimizer but unfortunately I do not have any License for this module.
Thank you in Advance
RE: Volume calculation (Bidirectional)
I have not used scripts before and trying to learn a little. However I am unable to implement what you have explained.
Could you please explain more.
Thank you
create the geometry, create a parameter that read the value of the volume. then record a macro that change the position of the plane.
That would be a good start. You can search the forum to find how to access the value of a parameter with VBA so you can check the new value after the solid update. Then you make a loop (I would do a While loop) until you get your volume within the tolerance you want. You can go without tolerance but it will be much slower.
Post your part and your code to get more help.
